2001 supercrew 5.4 wet engine
Old Nov 28, 2004 | 05:00 PM
Kel67's Avatar
I washed my engine now its running like crap,checked the plugs and dryed everything out and still runs bad,engine light comes on and off.
Old Nov 28, 2004 | 07:24 PM
JMC's Avatar
JMC
25 Year Member
Kel67,
Check the connectors to the coils and the injectors. If you got water in them it will casue your problem. I would also check the plug boots. Water can leak past them and casue havoc if it is not removed. FYI I have dielectric grease on all the connectors in my engine compartment.
Regards
JMC
Old Nov 28, 2004 | 09:01 PM
Gearhead99's Avatar
Not a good idea to wash your engine. Water [steam] will get into all electronics and mess them up.
I get a few a month that need work after they wash down the engine.
Leave it dirty..
Old Nov 29, 2004 | 08:36 AM
Norm's Avatar
A lot of us wash our engines regularly with no problems. You just need to be careful especially if you use a high pressure wash. Do not fill spark plug wells with water and soak you coils etc.
Old Nov 29, 2004 | 12:25 PM
BruceScrew's Avatar
If you are still having a problem, check the trottle position sensor. I had water leak into mine and it would not shift at the appropriate nornal shift points and ran like crap.
