Altinator
Altinator
I have a v-8 w.6L engine.(f150 of course), my altinator went bad for the 2nd time because I went cheap the first time and bought one at a salvage yard.
Question: It the altinator supossed to be 130 amp or 95 amp?
Question 2: Does it even matter?
Please answere quickly, Thanks! Semper Fidelis!
-koven carlson
-koven carlson
for future reference you might wanna check the brushes and everything if it goes out again.mine's gone out twice and i had to buy a new one the first time cause i couldn't find parts to rebuild it,but o'reiley's can get brushes and a voltage regulator for it.i think it was like 30 bucks for the regulator and 20 for brushes.its an easy fix and saves you alot of money.i know the 130 amp came with the towing package,but it might've come with other packages too.
It does'nt matter which amperage you go with. The regulator limits the output to no more than 15 volts regardless. The higher amp alternator will have more available power if you plan on adding any accessories and need the higher output.
