NO Oil Pressure
Old Nov 21, 2004 | 11:48 AM
OxfordSupercrew's Avatar
Unhappy NO Oil Pressure
I had the oil changed, and all was fine. Afterwords, my oil pressure guage dropped to zero and the temp and oil light came on when I was driving. After a second, it went off and the pressure returned to normal. Then, this morning, about 1 week later, I started my truck, and there was no pressure. After a few minutes, it came on and is working again. What could cause this? I checked the oil level and it's good, and there is no overheating or engine noise. Would the temp cause it? It was 20 degrees out. The first time I drove over a curb at an angle and was rocking pretty good, so I dismissed it as the movement. I'm stuck.
Old Nov 21, 2004 | 12:26 PM
JMC's Avatar
JMC
25 Year Member
It is most likely that the oil pressuer sending unit or the connector was disturbed when the oil filter was removed/replaced. Personally I would check it out. I would get a mechanical guage and check the actual pressure immediatly.
Regards
Jean Marc Chartier
Old Nov 21, 2004 | 03:07 PM
acadianabob's Avatar
yeah mine did that too. bad sender. apparently fairly common.
Old Nov 22, 2004 | 10:00 AM
atsioukl's Avatar
It's a faulty oil pressure sending unit. My 2001 Expy 4.6 had the same problem. The sensor cost about $10.00 at the dealer. Buy a new one and replace it at you next oil change. The sending unit is located on the oil pan next to the oil filter. Took me about 30 minutes including the oil change.
Old Nov 24, 2004 | 12:16 AM
nogojo31's Avatar
Re: NO Oil Pressure
Originally posted by OxfordSupercrew
[B After a few minutes, it came on and is working again. [/B]
your lucky, if you really had no oil pressure, your engine wouldnt have lasted a few minutes....maybe a few seconds.
