97 4.6L short block
You will pay a fortune for a prepped short block.
Try Sean Hyland Motorsports
http://www.seanhylandmotorsport.com/
Fox Lake
http://www.foxlakeracing.com/index.php
Team VT
http://www.vtengines.com/46gtSB.htm
There are more out there and as I think of them I will post.
Regards
Jean Marc Chartier
Fox Lake
Team VT
Regards
Jean Marc Chartier
Using a stock short block will save you a substantial amount of money. You can safely run about 10 lbs of boost. If you want to go higher then you will need to beef up your engine. Detonation will kill your pistons so be sure you get a proper tune for the application.
JMC
JMC
The pistons are the weakest part. If it detonates under boost you will blow a hole in the piston before you brake a rod.
But you point is noted and should one want to push more power a better crank and rods will be needed. The Cobra crank is forged steel and will take more power than the stock cast one. So I guess that while you have the engine apart you might as well go all out and get better rods too.
JMC
JMC
