1994 351 W engine swap
I have a 1994 f150 with a inline 6 in it. I was wondering if a 351 bolts directly in or if i need to make/buy motor mounts. Any help would be appriciated.
Also what else would be needed to do the swap?
PINKY
PINKY
if you have code "U" tranny, it SHOULD bolt right in. as for hoses, wiring, computer, you are on your own. it would "drop" in, and bolt to the motormounts, but electronics would be an issue. not responsible if any of this turns out wrong as i've never put a BIGGER engine in a vehicle. all i've ever done is just replace the one thats in it. and if it is running fine, i'd just leave it. IF IT AINT BROKEN, DONT FIX IT!!! if it is a 300, that is one of the best motors around, and it has just as much power as a 302, and prob gets better milage
