Weird Engine Problems Rough Idle Shaking Ect.
Old Oct 5, 2004 | 10:39 AM
superfluus's Avatar
Last night I tried installing a MAC throttle body on my 2003 5.4 without any luck. I think I broke the TPS.
It is more important to me to have the 5.4 working so I swapped the throttle body with a 4.6. The TPS reads .98 at idle and 4.65 at WOT.
The truck runs very rough and seems like it is missing. Idle is about 500, and it doesn't want to rev at all without shaking. When I put it into gear it starts shaking pretty bad.
HELP
Old Oct 5, 2004 | 11:36 AM
superfluus's Avatar
Just started the truck again...idle isn't rough anymore, about 750rpm. BUT as soon as you start giving it some gas the thing sounds like it is missing/major hesitation... maybe the correct term for this is "spuddering"? Also, it revs a lot slower than usual.
As soon as it's in gear the truck's rough idle comes back...which is around 500rpm
Old Oct 5, 2004 | 11:44 AM
superfluus's Avatar
Is there any difference between the 4.6 TPS and teh 5.4 TPS ?
Old Oct 5, 2004 | 11:46 AM
superfluus's Avatar
Oh, the engine light is on and the off light on the overtrive button is blinking.
Old Oct 5, 2004 | 12:06 PM
superfluus's Avatar
Here are the codes...
p0443
p1451
p1747
p0755
p0740
p0758
p1760
p0135
p0155
p0403
Old Oct 5, 2004 | 12:15 PM
superfluus's Avatar
Seriously WTF!?!? this all happened from trying to install a throttle body????
Old Oct 5, 2004 | 12:16 PM
mikeintx's Avatar
I dont know about the codes but it sounds like you might have a vacuum leak somewhere.
Old Oct 5, 2004 | 12:43 PM
superfluus's Avatar
I doubt it...the truck was totally fine last night...also, I get all the codes back within in the 1 minute of turning on the truck.
Old Oct 5, 2004 | 11:12 PM
olgzr's Avatar
It sounds like you left a vacuum line off or a connector off. If it ran good before you tried to install the throttle body, then I would look at everything you had loose or off.
Old Oct 5, 2004 | 11:38 PM
Pestco1's Avatar
Not exactly sure that you can swap out parts like that and expect things to run good as new. The first part was probably the ECM relearning the new set up. As for hesitation, Are the two throttle bodys entirely the same. Do you have a leak in the intake system between the MAF and the throtle body? Sound like lots of ways this project could have gone wrong.
Old Oct 8, 2004 | 02:26 PM
superfluus's Avatar
FIXED....It was a blown fuse in the wiring harness.
Old Mar 26, 2006 | 01:26 PM
thunder7's Avatar
which one? can you please elaborate, I think I might be having the same problem. Thanks
