White smoke from exhaust
Old Aug 30, 2004 | 11:21 AM
BamaScrew's Avatar
i have white smoke that is coming from the exhaust when i start my truck.....2002 screw.....it only last for a few seconds...is this normal?....im thinking not....i just had the cylinder coil replaced a few weeks ago....could it have anything to do with that?....any help would be greatly appreciated
Old Aug 30, 2004 | 03:00 PM
bigtruck311's Avatar
does the smoke smell like fuel? does it go away as soon as you reach operating temp? no CESL? still run the same to you?
Old Aug 30, 2004 | 03:01 PM
sgauthier's Avatar
might just be mositure from your exhaust burning off. if everything else checks out OK i wouldn't worry to much about it, unless your coolant is slowly going down. then i would be concern that you have a leaking head gasket .
Old Aug 30, 2004 | 05:22 PM
brahmus's Avatar
white smoke= moisture in exhaust
depends how bad it is here in southern Louisiana it is common but our humidity is 10000%
Old Aug 30, 2004 | 07:02 PM
olgzr's Avatar
Some white smoke is normal depending on the temperature and humidity. If you have a lot more smoke than other trucks do at startup, you may have a problem. Also, if the smoke smells sweet, it is probably antifreeze leaking into the cylenders and burning.
