High idle after port and polish?
Old Aug 2, 2004 | 03:24 PM
bigtruck311's Avatar
this weekend i ported and polished my throttle body and elbow, put it all back together and it was idling like 500 RPM higher than normal, checked everything for vacum leaks and there was none, so i took everything apart and adjusted the buterfly so it would make a better seal, put it all back together and it was allittle better on start up it goes form 1500 then after about 15 seconds it goes down to 1000RPM at idle this is still like 200RPM higher than what it was, i think more air is getting past my butterfly and giving me this higher idle, what do you guys think? thanks in advance
Old Aug 2, 2004 | 04:02 PM
spray004's Avatar
It could possibly be your throttle position sensor. Did you remove it to do you P&P work?
Old Aug 2, 2004 | 04:25 PM
yep i thought it might be that to so wile it was runing i disconected the TPS and there was no change so i dont think it is the TPS
Old Aug 2, 2004 | 07:25 PM
Neal's Avatar
HI!... Did you remove the TB butterfly when you port/polished your TB???? If you did the entire bore then I'm sorry to tell you, you now need a new TB. If you did the above then the bore of the TB is slightly larger than the butterfly and extra incoming air is sneaking by causing the high idle.
Old Aug 2, 2004 | 07:33 PM
ChevySniper's Avatar
bigtruck311
I just recently did mine and had to buy a new tps...it was my fault though. My idle was a little different after, but when I got it fixed finally it was back to normal...I just polished my elbow though.
good luck, hope you don't need a new tb like Neal said..
Old Aug 3, 2004 | 11:42 AM
yes i did remove the butterfly and i did polish and sand the entire bore, i too think that more air is getting by the butterfly, i think that if i plug the hole on the butterfly that it may fix the problem, i will keep you posted
Old Aug 13, 2004 | 05:50 PM
well bad news for me, i took the butterfly off and welded thesmall idle air hole that is on the butterfly with a oxy acetolen welder, well i geuse i heated it up to much i filled in the hole but when i went to put everything together i think that the heat changed the shape of the butterfly, so i got out my file and begane to try to corect it, well an hour latter i finaly got it all good put it together and i had to file it too much and i am back to axactly were i was before i broke out my welder, i just orderd a new bbk throttle body, let this be a warning to everyone to be very carefull when they attempt to port and polish the throttle body
Old Aug 14, 2004 | 01:20 AM
man that sux...sorry to hear that. How much did your new tb cost?
Old Aug 16, 2004 | 10:03 AM
200$ from troyer performance, i will get it this week,
Old Aug 17, 2004 | 09:04 AM
just received my new BBK throttle body, will install it this afternoon after i port out the elbow to match the diamiter, i will see if it fixes the problem that i made
Old Aug 17, 2004 | 12:16 PM
BruceScrew's Avatar
I replaced the original throttle body with a MAC 75mm and had nothing but problems with vaccuum leaks. As it turns out, the leak was either side of the butterfly bearings - cheap, very cheap! I purchased the BBK 75mm from Mike Troyer - what a huge difference. It runs and idles 100 percent better. The BBK is a high quality product - good luck and tell us high you made out.
Old Aug 17, 2004 | 02:25 PM
well i just got done porting and polishing the intake elbow to match the new throttle body, did it all at work(good to be a supervisor) took me like 2 hours tho, got it perfect, i am going to install when i get home we will see how it goes, i will keep you posted
Old Aug 17, 2004 | 02:29 PM
bigtruck311
cool man, did you take any before and after pics...that's something that I wished Ida done. Don't forget to adjust or at least make sure you trottle positioning sensor is at .99 or .98....very important after messing with that tb.
Old Aug 17, 2004 | 02:41 PM
i didnt take any before pics but i will take some after pics of the ported and polished elbow and of the instalation
Old Aug 18, 2004 | 10:29 AM
well finished install on the bbk, i love it started right up found its idle after about 30 seconds and is right were it is soposed to be 600 rpm, i cant really tell if there was any improvement but my a@s dyno says there is some emprovment, well i am satisfied, i just wish i wouldnt have messed up my stock one but all well
