Engine sputtering????
Old Jul 17, 2004 | 08:41 PM
crash666's Avatar
I have a 98 f150 with a v6. I don't know how to explain this. But the engine seems to sputter sometimes when I stop. I wouldn't say that it is cutting out, just acts like it wants to die. As soon as I give it some gas it goes. It has 90,000 miles on it. Could it be the fuel fliter? Water in the gastank? Any ideas? thanks
Old Jul 17, 2004 | 10:06 PM
mf150's Avatar
change the fuel filter. I change mine every 10,000 miles. cheap insurance.
drop in a bottle of Red line SI-1 fuel system cleaner.
see what happens.
Old Jul 19, 2004 | 06:00 PM
crash666's Avatar
I use a fuel injector cleaner regularly. Usually either slick 50 or STP. I'll try the filter though. Thanks
Old Jul 20, 2004 | 10:59 PM
84fordman's Avatar
if you run to much of the fuel injector cleaner it is also hard on them cause that has happen to me before i ran it to often
but i would try a fuel filter to just to make sure before i got into a lot of heavy detail
Old Jul 20, 2004 | 11:30 PM
Chicago_guy's Avatar
got a quesion for you crash
Mine does it also,, is it as soon as you start it back up after a short drive? Is it warm if not hot out maybe over 85 out? humid?? I think some how the fuel rails are getting warm and not injecting the fuel in properly, I have a super chips tuner that allows me to scan codes, and nothign comes up aftew mine does it, i change my fuel filter every year, but it seems to do it right after a short trip in the heat and high humidity, noy all the time but ever couple of months it will spurt, all i do is put it in neutral or park rev it a little and it goes away
Old Jul 21, 2004 | 08:06 AM
crash666's Avatar
I use a fuel injector cleaner about every 5,000 miles or so. I'm in Oklahoma. It's always humid here in the summer. I started noticing it when I started using the AC this year. At first I thought it might be the AC putting a strain on the engine. But it kept doing it after I turned off the AC. I notice it when I come to a stop sign. When I come to a stop it will sputter for a second or two. But then the engine will run normally.
