Speedo Is Off
Old Jul 9, 2004 | 11:55 PM
SNUFF48's Avatar
Speedo Is Off
HEY NEW TO THE SITE....
I RUN 265/75 16s AND MY SPEEDO HAS BEEN OFF FOR SOME TIME. LOOKING TO RECALABRIATE IT. SHOULD I GET THE COMPUTER REPROGRAMED OR REPLACE THE VVS GEAR?
AND JUST WHAT IS THE VVS GEAR AND WHERE IS IT???
THANKS......
1997 F-150 W/ REBUILT 4.2, 4X4, RUNNING 265/75 16s
WITH 118K MILES ON THE BEAST......
Old Jul 10, 2004 | 02:24 AM
Johngs's Avatar
1) For future reference it is considered that you are yelling when you post in all caps (ie, its rude).
2) Do you have the digital odometer or the analog? If it is the digital one, you need to get your computer reprogrammed. If its the analog you need to change the gear, which should be located somewhere on the rear differential I believe (do a search on VSS).
Old Jul 10, 2004 | 02:20 PM
max mitchell's Avatar
Welcome ! 1997 = the gear is at the transmission (4X2) or transfer case (4X4). If you do search, try "VSS". Here is a guide.
www.finer.com/internet/pages/speedo.htm
Old Jul 11, 2004 | 10:46 AM
SNUFF48's Avatar
To Johngs,, thanks... new to the message boards...
To max mitchell,, thanks, it is an 4r70w automatic
then what is the cable coming from the top of the differnetial?
Old Jul 11, 2004 | 12:41 PM
Trucks with RABS (rear anti-lock brakes) have an ABS sensor that mounts to the top of the differential housing and reads 1-channel.
Old Jul 11, 2004 | 12:57 PM
SNUFF48's Avatar
thanks max m............
