Zex Nitrous Oxide
Old Jul 8, 2004 | 04:40 PM
zraptor's Avatar
Talking Zex Nitrous Oxide
Hello all,
I have recently upgraded to a 100hp shot zex nitrous kit on my 5.4L and let me tell you, its definetely worth the money and relatively easy to install. Cut seconds off my quarter mile!
Old Jul 8, 2004 | 10:14 PM
LE PEW's Avatar
Coolest, is a 100 shot safe for your engine? What were your 1/4 mile times before & after the ZEX install?
Old Jul 8, 2004 | 10:55 PM
Neal's Avatar
Cool
HI!... I hope you have a chip and have compensated for the nitrous via timing changes. IF NOT, KABOOOMMMMMMM!!!!!
Old Jul 9, 2004 | 01:53 AM
zraptor's Avatar
100 is safe assuming you are careful and dont use it at a lean air/fuel ratio. also may want to consider upgrading fuel pump.
No i did not adjust the timing chain directly however i did adjust the retard to 0 degrees. this is a zex "smart" kit, it monitors fuel pressure vacuum and air/fuel ratio. as long as you adjust the retard, you are ok at a lower H/P shot.
Old Jul 9, 2004 | 07:00 PM
Neal's Avatar
HI!... What's your 1/4 mile times then? Please no G-TECH PRO #'S
General rule of thumb is to retard your timing 2 degree's for every 50H.P of nitrous.
Old Jul 9, 2004 | 07:25 PM
zraptor's Avatar
low 14's
Old Jul 10, 2004 | 12:10 PM
zoomer20034's Avatar
where did u get it?...i want to put some nitrous on a for lightning and i can't find anyone who has it
Old Jul 10, 2004 | 02:11 PM
max mitchell's Avatar
zoomer20034-
Welcome ! You can't find nitrous for a Lightning?
http://www.powersurgeperformance.net...mance+Products
Old Jul 10, 2004 | 06:36 PM
no i couldn't...thanx alot
Old Jul 10, 2004 | 06:44 PM
does anyone know where i might be able to find it for like 450 or 500?
Old Jul 10, 2004 | 07:42 PM
Neal's Avatar
HI!... zraptor : I run LOW 14's with my truck in N/A trim. I'd probably go low 13's, high 12's with a 100 shot and a set of slicks.
Old Jul 10, 2004 | 11:59 PM
zraptor's Avatar
Neal, all i have upgraded under the hood it the nitrous, MAF sensor, Throttle body spacer, and of course the nitrous. I dont have as much done as you.
Banks
2000 XLT 5.4L
Old Jul 11, 2004 | 12:01 AM
zraptor's Avatar
correction, and AEM brute force
Old Jul 11, 2004 | 03:29 AM
Neal's Avatar
HI!... Yes I realize you don't have as many bolt ons as me, but all my mods only made 80H.P (FLYWHEEL). Your ZEX kit starts you off with 20H.P more than that and then you do have the few mods that you have done.
Old Jul 11, 2004 | 05:18 AM
Intel486's Avatar
Don't consider it. DO IT! The ford pump died out on me and I got detonation...
Also, don't mind Neal... he said stuff to me about him being N/A and fast when I got my nitrous... I don't think he likes nitrous.
