Where to mount the Amsoil dual oil setup?
I bought the Amsoil dual remote filter set up and was wondering how the heck i am going to install it in my truck? any ideas? I saw the one on the amsoil website. for the f150. Where did that guy get that bracket? Anyone who can help with this i would appreciate it.
its a 2002 f150 5.4 4 wheel drive.
Originally posted by polishpowersge
how did you mount it to the frame? just tap it and use some sheetmetal screws? or soemthing like that? I dont see how you would get a nut on the other side.
dual remote install on F-150 using bracket.
You can use a bolt with a nut if you use a stong telescoping magnet to put the bolt through the hole from inside the frame. I did it a few times because I decided to replace the bolts with longer ones. It's a quick and easy install when you have a good plan.
I have some recent pictures now that I have a digital camera that I could upload. I also have an oil analysis online at BITOG.
Hey guys well with a little elbow grease i got the dual mount installed. I had no problems with leaks. But i did have a problem drilling out the bracket holes......... They didnt line up the first time.
That was kinda a pain. I do have a problem though. I cant put my skid plate back on cause the bypass filter is in the way. I dont think i could have gotten it any higher though. Its like right up there next to the radiator bracket almost. Im thinking of modifying the skid plate. Anyone know if antyhing else?
