engine swap?
Old Jun 25, 2004 | 02:32 AM
Wayne Henson's Avatar
engine swap?
I was curious, if the 4.6 can be replaced with the 5.4 or are they different engine families. I have a 1999 F150 with a 4.6 and is running great now!! Thanks for any info, Wayne
Old Jun 25, 2004 | 07:28 AM
JMC's Avatar
JMC
25 Year Member
The bolt pattern on the bell housing is the same. You can put a 5.4 in where the 4.6 was sitting. There are a few differences in the locations of some of the sensors but it is not a biggie. It is easier to use the wire harness from the 4.6 than to try to match up the 5.4 harness to the 4.6 PCM connector.
Regards
Jean Marc Chartier
Old Jun 25, 2004 | 07:32 AM
Dan7's Avatar
There's a lot of info in this thread on the subject.
https://www.f150online.com/forums/sh...s&pagenumber=1
Old Jun 26, 2004 | 01:22 AM
simply said, Thank you
I do thank both of you for the info
Old Jun 28, 2004 | 03:24 AM
madferraristi's Avatar
I have done a similar swap, I put a Lightning engine in place of my std 5.4.
I have ALL of the parts you will need, send me an e-mail for more.
