No DPFE Sensor?
Old Jun 16, 2004 | 12:54 PM
Fordusa06's Avatar
Question No DPFE Sensor? (Includes Picture)
Hey Guys,
I recently have had trouble with my EGR and I thought it may be the DPFE sensor, so I purchased one from the local Ford shop and I went to put it in, and in the area it is supposed to be it is no where to be found. I am wondering what might be the problem here. Could it be that it is hiding somewhere else, or does it not have a DPFE sensor at all. I am at a loss of ideas. Thanks in advance. All help is appreciated a ton!
Vehicle Information:
2001 F-150
4.6 V8
____________________________________
This is what it looks like inside:
Old Jun 16, 2004 | 04:58 PM
grinomyte's Avatar
well it's certainly not where it's supposed to be.
I don't see the connector or the tubing that suppose to be going to it. Almost directly below that there should be two metal small tubes diverted off the egr tube i think. Check those out and see where they lead to i guess they could have purchased an aftermarket one and relocated it.
Yes it is the egr tube, just follow it down, should be about a 1ft down the pipe from the egr valve there should be two small pipes out of it.
Old Jun 16, 2004 | 07:03 PM
temp1's Avatar
Go look at this article and compare your picture with the articles picture.
http://www.fordf150.net/howto/throttlebodyclean.php
The DPFE should be located right above the power steering
reservoir in your picture but it appears to be missing.
Old Jun 16, 2004 | 10:31 PM
Home skillet's Avatar
Ford kept the throttle body cover bracket the same when they updated to the smaller DPFE.
The DPFE is located closer to the EGR valve-it's a small square black box about and 2 inches by 1 inch. Also has two hoses connected at the bottom of the sensor.
Old Jun 16, 2004 | 10:52 PM
jstang's Avatar
closer to the firewall, drivers side.
Old Jun 16, 2004 | 10:56 PM
Fordusa06's Avatar
Alright, thanks guys! Found it, Ford gave me a kit to install another one, looks good. Thanks Again!
Old Jul 13, 2008 | 03:23 PM
JTDEERE's Avatar
Wooo I just thought mine was missing too. Good thing I found this thread!
