p0174 code where to start ?
Old Jun 15, 2004 | 12:22 AM
DFWTexasford's Avatar
Hey all i have a 1999 f-150
I have noticed my ses light come on and took it to auto zone and found out that it says i have a p0174 running lean on only one bank.
I have seen others talking about cleaning the MAF sensor wires?
any suggestions? before
i get started
Old Jun 15, 2004 | 05:37 AM
BlueOvalFitter's Avatar
Check all vacuum lines,esp. the ones running to and from the pcv valve.These are known to get holes in them and throw that particular code.Good luck and keep us posted.
Old Jun 17, 2004 | 01:20 AM
CODE P0174
I still have not checked the pcv hoses yet , I did spray my MAF
sensor with contact cleaner but the light came back after 11 miles
after I reset the computer I wanted to add another thing , I have
not had any rough idling
that I can tell, Will this seem to point to a certain set of things to
look at first? (OXYGEN SENSORS)?
If there were any type of vacuum leaks wouldn't my
engine be idling rough?
89000 miles
Old Jun 17, 2004 | 08:17 AM
temp1's Avatar
Do you have the 4.6L engine?
Have you checked the rubber elbow that attaches to the intake plenum?
https://www.f150online.com/forums/sh...ht=p0171+elbow
You can look at causes for the p0171 here.
http://www.v8sho.com/SHO/TSB0197HO2SServiceTips.htm
Old Jun 17, 2004 | 08:32 AM
Yes I have a 4.6
Old Jun 17, 2004 | 01:19 PM
temp1's Avatar
Originally posted by DFWTexasford
Yes I have a 4.6
Look for vacuum leaks next...
Old Jun 23, 2004 | 01:29 AM
I found a vacuum leak above the PCV valve I am going ti autozone to get the parts I need to repair this
Old Jun 23, 2004 | 01:31 AM
I actually found it at the rubber elbow you mentioned above...
This has to be what is setting off the code....
Old Jun 23, 2004 | 01:31 PM
temp1's Avatar
Thanks for the feedback and let us know how its going. Autozone might reset your ODBII code for free but if they don't then you can disconnect the battery for 30 minutes and that should clear your code.
Old Jun 23, 2004 | 11:53 PM
I actually disconnected my battery for about 5 mins after repairing it and the code has not returned aftre driving it for 30 miles
Old Jun 24, 2004 | 05:53 AM
The CEL should not appear with that code again if you replace all the leaking vacuum lines.Did you buy the pcv kit(pcv valve,tube,rubber boot,misc. vacuum lines) from your Ford dealer? Ive had to buy a few from Ford to fix the same problem on friends' F150s and E150s.Thats why I said originally to check your vacuum lines;been there,done that! Glad to hear its fixed!
Old Jun 25, 2004 | 11:49 PM
The PCV valve was still good I actually purchased a piece of GOODYEAR vacuum hose and it works great.........THANKS AGAIN ! ALL
