Hole in cylinder head leaking coolant. How many has this happenned to?
I have a 2000 F150 with the 5.4L. At around 68k miles I developed a coolant leak in the cylinder head directly under the thermostat. Ford replaced it and made me pay 25% ... fast forward ahead to 110k miles and It has done it again. I have read at least 2 old threads here that indicate the same problem.
The inside of the water jackets had corroded(worn) away until it finally broke through the outside was as a pinhole. the inside of the head was completely corroded out. I havent called ford but this cant be acceptable. This is a definate flaw.
If you have had similar problems ... post here so we can see how many and what ford has done about it .... i will post back here after I call the regeonal office to see what they will do about it!!!
It has not happened yo mine. but I have the 4.6 and an extra grounding strap running from the Negative battery terminal to a bolt on the ehgine front cover. Your situation sounds like electrolysis to me. read the following. http://members.shaw.ca/autocheck/electrolosis.htm
Although this will not fix your current problem it may keep it from reoccuring. The current fix would be to have the hole welded shut.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
I put JBweld on it and it lasted 20k miles .... guess I can only jbweld it again.
Sucks though because i am always worrying about when it is going to start leaking again on a trip. I am amazed that this cant be a commom problems ... what would be the chances I got two defective heads?
Just wanted to refresh this posting. After posting this i talked to ford with no avail. So i JB welded the hole shut. That lasted about 20 thousand miles twice. I am now at 166k and did a better patch job with aluminum bolts and jbweld.
I was just curious how many people have seen this problem?
