Please Help!! Motor Swap Questions
Old May 2, 2004 | 03:08 PM
wakechik24's Avatar
I was wondering if anyone could help me out. I have the dreaded 97 f-150 4.2L with well over 200K miles on it. I know that i need to be thinking about a new motor here pretty soon. I am hoping to replace it with a bigger engine but i dont know if it can be done. i understand that i am going to have to replace mytranny and my computer and in order to pass smog it has to be a 97 or newer motor. But i have been told that the electircal is hell. If i replace my motor to a bigger model can my wiring be hooked back up so that my stock instrument panel will work? i live in California where the smog laws are a pain in the *** to say the least and in order to pass smog all my warning lights have to function. I NEED HELP!! Can i change the engine in my truck and still pass smog???
Courtney
1997 F-150 4.2L 4x2
7 1/2" Fabtech lift with bilstien shocks
315/75/16 BFG AT/KOs
4.56 gears
Edelbrok exhaust
K&N Intake
Old May 5, 2004 | 01:36 PM
madferraristi's Avatar
It can be done, legally.
You have mail.
Old May 6, 2004 | 05:04 PM
Capri's Avatar
I have the same set up and would like to swap in a 96 5.8. Can you help me too? Thank you in advance.
Old May 6, 2004 | 11:06 PM
I don't know about NJ but in CA we are only allowed to swap to an equal or later year model.
Old May 7, 2004 | 09:59 AM
Capri's Avatar
I thought the 5.8 was available that year. ?? I have a nice 351 that is a torq monster, it is a long rod motor, perfect for a truck.
Old May 17, 2011 | 08:22 PM
lotusteve's Avatar
4.6 2v swap question's
HI! I also need info like you.
I am in process of installing 2005 4.6 2v I have the engine ,Transmission,PCM,
wiring harness, ignition key, Pats transponder.Do I also need special tune if I
do not have dash instruments from the doner vehicle?
Thank's in advance.
Steve
Old May 18, 2011 | 11:15 AM
The instrument cluster issue may be insurmountable.
There are two possible resolutions. First, do a little research, you can buy wiring kits that allow the installation if such an engine and transmission in a street rod so that might be a possibility. You could also look into using a '97 or '98 PCM.
The dash instruments in these years were not tied into the PCM, at least to a lesser degree. I know that in order to put a Lightning engine with PCM into either of those years, one has to change the cluster and dash wiring harness as well as the engine bay harness, etc.
Old May 18, 2011 | 11:30 AM
jethat's Avatar
This thread is 7 years old and probably not related to your situation much. Welcome to the site next time start a new thread infact maybe you should just do that..
Thank's in advance.
Steve
Old May 18, 2011 | 11:32 AM
mxr181's Avatar
oops
