Gage lights
Gage lights
f-150 xlt lariat==1990
The gage lights don't work in my truck. Must have to drive at night cause i will get in trouble for my neons or interior lights. I need to know where the fuse box is so i can check the fuse. I know bout the box under the steering wheel. There is one under the hood somewhere. If anyone knows exactly where it is i would appreciate the help. Also, i need to know where the actual lights are for the gages and if i need to remove dash to replace or look at them. thanks
had the same problem. my cel light and all the lights that lit up the guages were burnt out. you need to take all the plastic panels off around the instrament cluster, then unscrew it and pull it out. all the lights are in little black holders that you can just turn 90 degrees and they come out. a few bucks at the dealer for all the lights.
