5.0 check engine code (0401)
Old Apr 11, 2004 | 01:19 PM
carstocks's Avatar
I have an explorer with a 5.0 liter that I intend to sell soon. she has set off the check engine light. the code I am getting is 0401.
The "generic" manual states that it is:
Exhaust gas recirculation flow Insufficient detected
Any ideas on what is the cause and what is the fix?
Thanks,
Mike
Old Apr 11, 2004 | 02:16 PM
Johngs's Avatar
Try doing a search on P0401
Cleaning the EGR valve might work, or it several other things. But this is a cheap/easy thing to try, so its a good place to start.
Old Apr 11, 2004 | 05:20 PM
carstocks's Avatar
thanks for the info.
Mike
Old Apr 11, 2004 | 08:58 PM
projectSHO89's Avatar
A P0401 is seldom caused by the EGR valve.
It is most often caused by either clogged EGR passages in the intake/throttle body or by a faulty DPFE sensor.
A simple vacuum test will tell you which direction to look.
Steve
Old May 19, 2004 | 09:52 PM
LeDuk's Avatar
The EGR valve is tested by applying vacuum to the EGR while idling. The engine should stumble or die.
If that tests OK, it is probably the DFPE sensor. I just installed one today, and I shook water out of it and the ports were almost clogged with corrosion. A bench test revealed very sluggish operation.
The DFPE is obviously a Break-A-Matic part, and is listed as a main source of problems on other Ford models as well. Suspect it anytime you get pinging on acceleration and you have cleaned the fuel injectors already.
