EGR Valve Symptoms
Old Mar 8, 2004 | 03:50 PM
Hymis's Avatar
EGR Valve Symptoms
Hell All,
Can anyone tell me what symptoms would show if my EGR valve was failing. Is there a way to check it? Thanks for your help!
Old Mar 8, 2004 | 11:06 PM
plug's Avatar
The EGR valve opens under high heat to allow exhaust gas to reenter the combustion chambers to help cool the engine. a faulty EGR valve may not open. sometimes it can be a loss of power almost like a miss. Most of the time the DPFE sensor is the culprit. to test the EGR valve, crank the truck and leave it in park. now put a piece of aquarim tubing or gas hose on the EGR valve where the green vacuum hose is plugged. suck on the end of the tubing, the truck should begin to stubble as if it is going to die. if this happens, the EGR is good.
But, if your EGR ports are clogged, the truck will not stumble. you can put your finger under the EGR Valve and suck on the hose, you should feel the valve moving on the inside. make sure the engine isn't too hot when you do this, as the EGR valve gets extremely hot from the exhaust gases. if you don't feel the valve move and the truck did not stumble, then you could very well have a faulty EGR.
remember, the DPFE sensor actually detect how much the EGR is too open. it sends a signal to the PCM which then sends the correct amount of of voltage to the EVR solenoid. this is what opens the EGR valve. The DPFE sensors are famous for clogging up with some type of white grease like crude.
hope this helps.
Old Mar 18, 2004 | 12:12 PM
Hymis's Avatar
Plug! The truck only misses and pings when the truck is cold. Even once the engine warms up it still misses and pings until the engine compartment warms up, then the truck runs fine. Could this be the EGR? Is there anything else I should be looking at? Thanks for your help.
Old Apr 2, 2004 | 03:38 PM
pushrod's Avatar
Hymis, you have a significantly different engine than stock, so any number of things in the ECM could be causing your cold engine driveability problems.
Other than the EGR (system), which could cause pinging, but normally on a hot motor, you might check the plugs. From what I've seen and heard, do not use anything other than Motorcraft platinums, and when you replace them, use the doubleplats.
Good luck!
Old Apr 2, 2004 | 04:44 PM
Hymis's Avatar
Pushrod! Thanks for the feedback. Do you know what gap I should be using for the plugs? Thank you!
Old Apr 5, 2004 | 09:29 AM
864Lightning's Avatar
I would suggest posting your questions in the Lightning forum.
There are lots of people there that have added superchargers to the Gen1 naturally aspirated engines. They have alot of experience troubleshooting the bugs that go along with them.
Make sure you tell them what year model your truck is,, there is alot of difference between the older eec5 and the OBD-II systems.
