HELP! EGR - almost there!
Old Mar 7, 2004 | 08:25 AM
DBLD's Avatar
Hi Folks,
I have been posting about my check engine light on my 97 F150, 4.6L. Code pulled has been 401. I replaced the DPFE with a new one, cleared code, light came back on again. I took a shot at removing the EGR valve for cleaning, and had some bad luck with the first bolt, and I had an awfully rusted/tight nut connecting the EGR valve to the exhaust tube. Ok, after soaking overnight with PB blaster, I finally got the EGR valve off!
Now what do I do? I know I am supposed to be cleaning something, but I am not sure what to look for. The EGR seems to have 2 openings - one that connected to the exhaust tube, and one that connected to the (i think) throttle body. I cleaned a little carbon out of there - but it didn't really look that bad. What should I be doing?
Also, if I blow into the little tube that is on top of the EGR valve (the tube that the green tube hooks onto) - should anything happen? Should I feel any flow of air coming out anywhere - because I tried and I don't feel any air. Guess I'm wondering how I know if my EGR is clean or not.
Thank you SO much! I know it may not seem like much, but for an automotive novice like me, this is great!
Old Mar 7, 2004 | 09:10 AM
projectSHO89's Avatar
The SEARCH tool will help you find many recent (last week) threads with more than enough information to solve a P0401 code. Otherwise, just scroll backwards for a few days and look at the titles of previous threads.
Steve
PS. You have to suck on the vacuum line, not blow. It is a vaccum, not pressure, operated valve.
