Check Engine light is on code P1451 5.4 F-150
My check engine light is on. I just went to autozone and got it scanned. The code it came up with is P1451 and it says Evap Emission Control System Vent Control Valve Circuit. at the bottom of the print out. Any Ideas?
P1451 is a problem with the canister vent solenoid and or circuits to solenoid.First start by checking solenoid resistence, should be 48 to 65 ohms. Next check for battery voltage to solenoid on red wire with the key on, engine not running. Solenoid is at rear of vehicle around fuel tank area. It has 2 wires 1 is red & 1 is purple/white.
I went to two different ford sites that gave a list of error codes. And for code P1451 it said this....... NOW im really confused. Has anybody seen this?
Lack of Response From Passive Anti-Theft System Module - Engine Disabled.
P1451 Evap. Emission Control Sys. Vent Control Valve Circuit Malf.
this is right off the ford code list
you might have gotten a obd 1 code or a dash computer code or something like that.
hopefully someone here that has the shop manual on disc will reply with the diagnostic procedure for this code.
My first reply was steps right out of the ford shop manual. The canister is right above or in front of spare tire. The canister vent solinoid is attached to the canister.
Thanks alot... I will take a look tonight and see what I come up with, I cant stand to see that Check Engine light any longer.. its a mentel issue I have
I let you know what I find
