Code P401?? Check engine light on.
Old Jan 27, 2004 | 08:10 PM
Orfordcop's Avatar
Do any of you smart Ford owners know what might be a cause for this code? I was thinking of replacing the EGR valve. Or is that too premature. Should I take the EGR valve off and clean off any carbon on it. If I do take the valve off are there any tricks?
Thanks for all the great forums. Nice web site to see.
Oh yea I have a 1997 F-150. 4.6 liter/ flareside XLT. Nice truck except the damm noises out of the front end at low speeds.
Old Jan 27, 2004 | 08:21 PM
AjRagno's Avatar
You need to remove the throttle body and clean the EGR ports
Old Jan 27, 2004 | 11:26 PM
STAN/SRMASTER's Avatar
Remove vaccum hose on egr valve. Install a vaccum pump to valve,apply vaccum to egr with engine idling. If engine stumbles or dies ports are clear. Most of the time po401 is caused by a bad DPFE SENSOR
Old Jan 28, 2004 | 01:24 AM
AjRagno's Avatar
On a 2001-2003, I'd agree. Ford was still producing quality DPFE sensors back on 1997 however, and I've seen the 4.6L specifically clog the throttle body ports with carbon over and over again.
You let us know what you find, Orfordcop
Old Jan 31, 2004 | 06:35 PM
Orfordcop's Avatar
Thanks for the replys guys... I am getting ready to go on my days off and I'll mess with it then...
Keep them coming, Great info
Old Feb 5, 2004 | 06:53 PM
cachristian's Avatar
I had the same code on my 97 4.6 4x4. Spent money and time having people, including dealer to try and figure out. Finally, mechanic told me to try DPFE sensor. Cost around $75. Finally fixed it! Good luck!
Old Feb 9, 2004 | 01:09 AM
Orfordcop's Avatar
Thumbs up The p401 code
Finally got the carbon out, made a world of difference.
Changed the fuel filter too. Original filter was on at 94,000 miles.
Thanks for all the information.
Next week will be sparkplugs...
Old Feb 24, 2004 | 01:20 AM
anxvariety's Avatar
Does anyon have a more zoomed out shot of the DPFE SENSOR? I have no idea where this is..
My EGR valve looks like a flying saucer with a little green boot covering the top hole, going over to another thing.
