code P1451
Old Jan 25, 2004 | 03:05 PM
steve69's Avatar
code P1451
anyone know what code this is and where would the fuel tank pressure sensor be. 01 screw 4.6
Old Jan 27, 2004 | 05:03 PM
Throttle's Avatar
P1451 Evap. Emission Control Sys. Vent Control Valve Circuit Malf.
All Ford Codes
You are on the right track. It's a faulty canister vent solenoid, but you should check the harness for power first. It's located under the hood, a diagram of your engine should pinpoint the exact. I don't know off hand where it is on a 4.6. Dealer item only.
Old Jan 27, 2004 | 10:26 PM
steve69's Avatar
thanks much. anyway to test it from the canister itself and is there anything i need to do while testing for power, like have the truck on or off etc...
