Runs terrible when cold, great when hot
Old Dec 5, 2003 | 01:34 PM
Hymis's Avatar
Question Runs terrible when cold, great when hot
Hello,
I have a 95 F-150 302 supercharged. A week or so ago the truck started running horrible in the morning. The truck spits and sputters, pings etc. and barley makes it down the road. I tried adjusting the boost retard, but that made no difference. Eventually when the truck is warm it runs great! My mechanic cant figure it out, thinks it might be my computer and I really dont want the the dealership working on this truck. What doesnt make sense is that when the truck sits all afternoon and I leave work at the end of the day the motor is obviously cold but the outside air temp is between 65-80 the truck runs fine. Only when the entire engine is cold from sitting overnight does it run bad. I'm not sure if I have a bad sensor or what it may be. I have a ton of modifications done to this truck and I dont know where to begin. Any advice you can offer would be greatly appreciated. Thanks for you help.
Old Dec 5, 2003 | 01:38 PM
crashz's Avatar
Could it be you thermostat sticking open? Any check engine lights? What oil do you use?
Old Dec 5, 2003 | 01:42 PM
Hymis's Avatar
I installed a new thermostat about a year ago. I use mobile one oil only.
Old Dec 5, 2003 | 03:39 PM
Hymis's Avatar
No check engine lights. If there were codes would they be present without having the check engine light comming on?
