fuel pump?
I have a '95 F150 4x4 (5.8L). I was out of town on business, got back in truck after meeting and truck would turn over but not start. I thought battery might be draining and was able to jump start (somehow) after about 5 minutes.
Now the fun starts...I started down the road and engine started bogging down. It was almost as if I was running out of gas, though the gauge was registering 1/4 tank. I pulled over at a station and popped the hood for quick visual check. The engine idled perfectly. I pulled back out onto road and once again...the same results. The further I would press the accelerator, the more the engine would bog.
I stopped again and shut off engine. Would not start back. I noticed that I could no longer hear the "whine" of the fuel pump when turning on ignition. All I could hear was a single click about 3 seconds after I turned the switch.
I managed to start one more time by turning switch on and off a couple of times to prime pump. That was it. Got the truck towed back to my house.
Where should I start? Would a bad relay allow the engine to operate somewhat before it went out? Or are we definitely talking about a bad fuel pump?
If fuel pump, is this something a novice mechanic should try to tackle?
Any help is greatly appreciated!
