Can Someone Help
Old Nov 20, 2003 | 10:39 PM
BIGMIKE00's Avatar
Question Can Someone Help
HEY, I HAVE A 2000 F150 XLT 5.4 I AM LOOKING AT A 160 THERMOSTAT, WILL THAT BE A GOOD THING OR A BAD THING THE REASON I ASK IS I DO NOT KNOW WHAT THE FACTORY IS, AND I DO NOT WANT TO BURN UP MY WATER PUMP
Old Nov 21, 2003 | 12:06 AM
Pestco1's Avatar
You need to use at least 180 to get the engine controls to work properly.
Old Nov 21, 2003 | 09:07 AM
tkarter's Avatar
The factory stat is is 195 degrees. This usually maintains engine temps of 200 or slightly less.
I doubt a 180 would bother things much but a 160 would probably gunk the engine up so bad from running cold that there would be issues with more than a waterpump.
tom
Old Nov 21, 2003 | 04:54 PM
jello's Avatar
160 would not be a good idea
