Check Engine Light trouble solved
Old Nov 15, 2003 | 07:30 PM
Lou Colmo's Avatar
Smile Check Engine Light trouble solved
About a month ago my CEL came on after hitting a monster pothole( code PO455 ,Evaporitive Emmisions System Leak, Large), Well today I was putting rotors and pads on and I deceided to do somemore searching for the problem. I started tracing vacumm lines and I traced one behind the battery. Had to pull it to see the rest of the line and there it was, 2 vacumm lines that go into a rubber connector where broken off. I pushed out the broken pieces and fed in the good hose,problem solved. I know I saved at least $86 to have the dealer hook up their smoke machine and what ever else they would have charged me.
