weird turn signal
Old Nov 4, 2003 | 11:41 AM
bbqman's Avatar
Question weird turn signal
Has anyone experienced a problem with the turn signals on a 02 f-150?
Both signals work perfectly when the tilt steering wheel is in the upper most position. But when the wheel is lowered, the dash board indicator stops blinking and a "squeaking sound" begins in the steering column. I can move the wheel up and it begins working again and noise stops.
Wierd!!!
Old Nov 9, 2003 | 12:44 AM
mdwilli's Avatar
It may be the extension harness in the steering column. The plugs have a tendency to break and cause intermittent problems.
Old Dec 4, 2003 | 02:36 PM
larry202br's Avatar
did yo uever fix this problem? sometimes when I start my f-150, the left turn signal comes on and blinks rapidly. If I wiggle the turn signal stalk, it will (so far) stop.
