Check Engine Light
Old Oct 19, 2003 | 02:58 PM
STGCMTED's Avatar
Check Engine Light
Last spring, my 4.6 with 76K miles on it ran rough for about 10 seconds and the "Check Engine" light came on. I took it to the Ford dealer who looked at it and said that it was caused by a miss fire but was running OK. They recommended a complete tune up and then erased the computer code. All was well until it briefly ( 5 seconds or less) miss fired again and the check engine light came on. I replaced the excessively worn spark plugs (never again), the plug wires, fuel filter and pvc valve. Now it purrs like a kitten but I couldn't reset the "check Engine" light. Is there any way for the do it yourselfer to reset or turn off this light until something else causes it to light.
Old Oct 19, 2003 | 07:11 PM
Johngs's Avatar
I believe you have to disconnect the battery for ~30 minutes.
Old Oct 20, 2003 | 03:56 PM
D's RIG's Avatar
yes disconnecting the battery will do it,
Old Oct 21, 2003 | 10:11 AM
mikemike98's Avatar
after you disconnect the batt. the engine will prob. run rough for a few minutes.
