Got the Codes EEC-IV
Old Oct 12, 2003 | 12:18 AM
mdstud's Avatar
Ok guys I got the codes to flash on my '86 F150 302 V8 EFI, I got two codes 31 and 51, the injectors are dumping way to much fuel... so I think thats the ECT sensor, but my book says 51 can also be Air charge temperature sensor... just curious but where is this air temperature sensor...? and how would I test both the air temp sensor and the Coolant temp sensor..? As for the 31 code, Ill recheck the connection @ the EGR valve...Thanks guys for any help
Old Oct 13, 2003 | 11:11 AM
mdstud's Avatar
ok guys I tested the ECT and Im not getting any ohm reading so I think its bad, replacing it today.... I also checked the EGR connection and everything was tight, so any ideas on whats causing the error 31 code? Thanks guys
Old Oct 13, 2003 | 10:56 PM
Goldenfeather's Avatar
code 31
Air Intake temperature sensor is located on top of manifold, front, drivers side I believe code 31 is Throttle position sensor
Old Oct 14, 2003 | 12:41 AM
mdstud's Avatar
Well troublecodes.net says 31 is EGR Valve Position/Pressure Feedback EGR Circuit Below Minimum Voltage, also my chiltons book says its the EGR position sensor... I guess Ill check the voltage at it...
