Thermostat hmmmm
Thermostat hmmmm
Hey guys I was cleaning my throttle body, drained radiator, so with it removed I figured what the hell I might as well replace the t-stat while I have the radiator drained... Well I got the hoses off, and got the top bolt off but theres a bottom bolt buried under everything, I tried getting @ it with a regular wrench but it was just stripping it, its too small a space to get a socket in there... the dam a/c compressor mounting bracket and water pump are in the way... O its a 86 F150 302 v8 EFI, what do ya guys think?
ok thanks Ill werk on her today, I found some of the things so dam hard to get too... like the ignition coil its underneath the same bracket as the dam thermostat lol... and the fuel rail, u have to take apart half the f'in engine just to see it... Id like to shoot the guy who designed this, ah well just rantin and ravin Thanks guys
Well guys I got the t-stat changed after many hours of cursing... I didnt have to take water pump or anything off just had to move the ignition coil... I still can't find the dam Diagnostic connector, I searched the whole firewall and under the dash and around the front fender nothing... I know its eec-iv, could someone atleast tell me where the ECM is...? Thanks guys
ECM should be right front kick panel. Diag. connector is right side fender almost at the firewall. You can follow the spout connector from the dist. to the wire harness and eventually run into it
Thanks again Pestco found the diag connector, right behind the battery, I must have looked @ it a thousand times and didnt think anything of it.... Well my ongoing sagga continues... I got the therm changed... put all the top end of the engine back together, now all I have to do is put the fuel tanks back on and change the fuel filters... one thing though the guy @ napa said there should be a canister filter on it... but the only canister looking thing on there was the fuel switcher valve where all the lines from both tanks come together... so I try getting the bottom to screw off with an oil filter wrench, and baam it snaps, now I need to buy a new $160 piece of equipment... ahhhhhhhhhhhhh well I searched everywhere and couldnt find anything else along the fuel line that looked like a canister... so Ill give up on that filter right now... I found the other filter though =) anyway does anyone know if my truck was even equipped with a canister type filter? its a 86 F150 EFI 302 v8... Thanks guys u r lifesavers
