Rear main seal
Old Oct 5, 2003 | 07:26 PM
Goldenfeather's Avatar
Question Rear main seal
Please help I have an 87 F150 302 4x4 How to tell if rear main seal is bad ...what symptoms..etc. GF
Old Oct 5, 2003 | 08:37 PM
belly boat's Avatar
Account Suspended For Inappropriate For Using Email System To Send Inappropriate Messages
check to see if you have oil coming from between the motor and tranny!!!!!
Old Oct 5, 2003 | 11:34 PM
Rear main?
Thanks Belly boat...that is why I'm asking...think there is oil leaking but I'm trying to locate a seriuos power steering leak at this time ...Alot of fluid under there...engine runs bad, no power, wont start, only when hot
Old Oct 6, 2003 | 02:31 AM
Pestco1's Avatar
Rear main itself would not have much to do with engine performance other than to indicate a high milage situation. If you get engine oil comming from the small drain notch in the bell housing then you can bet its the rear main.
Old Oct 6, 2003 | 07:47 PM
Pestco help please
Pestco,
This may be up your alley...The vacuum lines going to TAD EGRC selenoid set are melted,have been looking for some at junkyards no luck yet...these are hard plastic lines with elbow connectors for 87 F150 302 EFI. Can some other line be substituted without collapsing?
Thanks Goldenfeather
Old Oct 6, 2003 | 09:14 PM
mdstud's Avatar
On my 86 302, all the vacuum lines are in a wiring loom, if there is none go pick up a cheap one @ the local autoparts store it should help with melting vacuum lines, also make sure there routed properly
Old Oct 7, 2003 | 12:26 AM
mdstud's Avatar
O one more thing on my 86 the power steering fluid was gushing out everywhere, then I noticed one side of the cap was busted, replace the cap and no more leaks. Just somethin else to check.
Old Oct 7, 2003 | 01:51 AM
Pestco1's Avatar
You can use regular rubber lines no problem. Ford loved those hard plastic/color coded things. I used to save the ends and as much of the plastic going into them. Then slide the rubber over the plastic and run it where it needs to go. If you need to though you can certianly use just rubber
