rusty sparkpugs
rusty sparkpugs
This is for a 2001 F250 w/5.4L
It started with the rough idle syndrome one day, so I figured I had a shot coil at approx 40000 mi. I bought a new coil and started to take apart the one I thought would be faulty. I thought it was the pass side, farthest back. I also decided to replace the plugs while I was doing this.
Well, it turned out to be the driver side, farthest back. Problem solved , but I can't understand what caused it to go bad. I also found the sparkplug for that cylinder plus the one right in front of it had rust on the threads. Then i noticed rust on a few other pieces of metal back there.
I'd like to know what could be causing this rust and how to stop it.
I would just suspect that you are getting water run off from your hood. I would not worry about it and if you are put some sort of deflector under the hood to deflect the water.
