code 8
Old Sep 30, 2003 | 06:48 PM
diveguy's Avatar
code 8
Hi,
I had my F150 in for repair for check engine lite. I said that a spark plug had come loose again (it's done it twice in the last 2 years) and was sometimes misfiring but not always. So the repair place said they got a code 8, which means the fuel injector needs to replaced. So they replaced the injector AND the spark plug. Does this sound right? I can't find code 8 in either diagnostic codes or odbII.
Old Sep 30, 2003 | 09:54 PM
Home skillet's Avatar
All OBD II codes have a letter and 4 digits.
Code "8" by it's self does not mean anything.
Injector failures are extremely rare.
Old Oct 2, 2003 | 09:49 AM
Throttle's Avatar
More than likely the mechanic is talking about code P0308 Cylinder 8 Misfire Detected. It can be anything from injector failure to coil or plug.
Old Oct 2, 2003 | 09:57 AM
Throttle's Avatar
Oh and ditto on Home skillet. The guy probably made some money off you. It has been my experience that injectors don't intermittent mis-fire, but I wouldn't stake my life on it. Oh, and another cause can be a wire for the guys with 4.2's and 4.6's.
Old Aug 1, 2007 | 12:46 AM
pmvachon's Avatar
Go to Autozone or Checker and they will pull the code for you.
If it is P0308, cyl. 8 misfire, I would check the coil pack first. I had the same symptoms and it turned out to be a bad cop.
Good Luck replacing it
Paul
Old Aug 1, 2007 | 01:08 AM
Welcome to the forums - but why are you pulling up 4 year old threads?
Old Aug 1, 2007 | 07:15 AM
projectSHO89's Avatar
"Noobie disorder". Just registered, a whole two posts....
Old Aug 1, 2007 | 08:31 AM
It does show that this person is using the search function - he/she just needs to pay attention to posting dates.
