What In The Heck Is This???
Old Sep 27, 2003 | 06:46 PM
unregistered's Avatar
My 351 has a strange tapping sound from the passenger side of the engine. It is so fast that it almost sounds like a "buzz." As you gas it, it gets faster and louder almost sounding like a loud unpleasant hiss, and kind of just stops when the rpms get pretty high, like something "lets go" or cuts loose.
It appears to be loudest around the spark plugs.
Funniest thing of all, it is quiet and fine when the engine is cold. Valves? Lifters? I hope not.
Old Sep 27, 2003 | 06:55 PM
Now that I think about it, it is almost more like a fast rattling noise. When You are going 35-40 it tends to happen most noticeably right before shifting gears (or could be the elevated RPMS cause it to seem louder then).
I thought transmission at one point but it does it after it is warmed up in park if you gas it. I even though the convertors were backed up because inside the truck it sounds like a hiss. Outside it is more like what I described.
Old Sep 27, 2003 | 07:00 PM
Sorry to keep going but one last thing, when it is warmed up there is a noticeable power loss, and it hesitates to shift a little. When it is cold, it is quiet and fast.
Old Sep 27, 2003 | 10:36 PM
mdstud's Avatar
Plugs torqued right?
Old Sep 27, 2003 | 11:07 PM
davet's Avatar
loose torque converter bolt or bolts?
Old Sep 28, 2003 | 03:24 PM
jstang's Avatar
on the back side of the heads is a crossover tube(exhaust) for emissions, only 1 bolt per side secures it to the head. check those.
Old Sep 29, 2003 | 04:03 PM
Throttle's Avatar
Sounds like the PCV valve problem I had. Check that too.
Old Sep 29, 2003 | 05:21 PM
Markus21's Avatar
Dirty Fuel Injector Maybe !
Try some cleaner, it wouldn't hurt !
Old Sep 29, 2003 | 08:57 PM
Dodge4x4's Avatar
Maybe it is the PCV valve rattling? If it is that, its a good thing.
Old Sep 29, 2003 | 09:58 PM
Tsquared's Avatar
A cracked exhanust manifold will cause this on a small block. It will be quiet when cold and when the manifold heats up it will buzz or sound like a lifter is going when it is hot.
