ABS Light is on
Old Sep 20, 2003 | 07:55 PM
Valk1500's Avatar
Question ABS Light is on
What have all of you been finding to cause the ABS light to be on in the dash? Mine has been on for a long time now???
Brakes are still working fine.
Old Sep 20, 2003 | 10:04 PM
Dewey's Avatar
A mechanic told me once that ninety nine times out of one hundred, it is the sensor that is right on top of the pumpkin. Don't worry easy fix.
Old Sep 20, 2003 | 10:13 PM
B-Man's Avatar
Cool
Ditto that. Helped a friend replace one on his Explorer not too long ago. Less than 5 minutes (1 bolt) and less than $20. It is right on top of the differential, offset to the driver's side.
Old Sep 20, 2003 | 10:53 PM
Valk1500's Avatar
Smile
B-Man & Dewey, Thanks for the input, I finally wised up and also found the posts under the Brakes section B-Man made for Craigs ABS Light problem. See you there with another question.
