Question for those using Ford Racing wires. . .
How well do the spark plug boots fit in the cylinder head?
I'm currently using Crane FireWire wires and found out that the plug boots let water leak past them and now I've got rustly spark plugs and rust crud built up.
Do the Ford Racing wires leak? Does anyone else have plug wire recommendations?
Yes water will go down into the holes which will cause rough running and your check engine light to come on.
You can buy aftermarket looms that will hold them or buy them from ford.
