Rough idle
Old Sep 9, 2003 | 11:55 PM
belly boat's Avatar
Account Suspended For Inappropriate For Using Email System To Send Inappropriate Messages
Rough idle
I have a 2001 4.6 4x4 ext cab. When I stop the truck it idols rough and when in neutral it is smooth also smooth when driving. What can be wrong???
Old Sep 9, 2003 | 11:59 PM
belly boat's Avatar
The dealer also changed all spark plugs new fuel and air filter. Cleaned injectors.
Old Sep 10, 2003 | 08:18 AM
plug's Avatar
numerous things, mine is doing the same thing. check for vacuum leaks, next the IAC should be taken off an cleaned, EGR clean that, make sure the DPFE isn't clogged. do yourself a favor and go buy a Haynes manual, and ohmmeter. this way you can check the specks on these components, to make sure they don't need to be replaced.
