Installed AF1 now wont idle
Old Jul 26, 2003 | 12:37 PM
batman9's Avatar
I just installed an AF1 FIPK today, and now my truck wont idle. When I start the engine the engine cuts off right when the engine starts. If I depress the accelerator when I am starting the engine the engine will idle, but as soon as I let off, the engine will cut off. Any help? I have a 1998 4.6l with 70,000 miles.
Old Jul 26, 2003 | 01:50 PM
canyonslicker's Avatar
It sounds like a vacuum leak. Check the hoses again to make sure nothing cracked.
Old Jul 26, 2003 | 02:25 PM
Habibi's Avatar
Is it possible the tube is pushed in too far, and covering the hole?
Sometimes it's a bit tricky to get it lined up just right.
Habibi
Old Jul 27, 2003 | 02:45 PM
Dustoff's Avatar
Check for leaks as mentioned above and also reset the computer by disconnecting the battery and letting it sit for a short while. I did not reset the computer after I installed my AF1 and the idle was very rough at first. Once I reset everything, it ran just fine. The AF1 is a great kit...I've had mine for a year and a half and have had no problems of any kind. Good luck!!
Old Jul 27, 2003 | 09:54 PM
03F15054FX4's Avatar
I had the same problem, after I knocked a hose off coming from the intake. There were 2 hoses, and the left one (if i remember right) came off. The truck wouldn't run with the tube off, unless I held the gas pedal.
