Spark Plugs Cracking
Old Jun 28, 2003 | 08:35 AM
stx98's Avatar
EVERYTIME IWASH OFF ENGINE I SEEM TO CRACK PLUG. MTR COOL.HELP
Old Jun 28, 2003 | 10:26 AM
DXprowler's Avatar
Is the engine cool when you wash it?
Old Jul 2, 2003 | 11:47 PM
stx98's Avatar
cracking plugs
motor is completely cold.do sparkplug wires shrink?
Old Jul 4, 2003 | 09:08 AM
Pickup Man's Avatar
Seems like water may be getting down in the plug well and then the plugs are cracking when they start getting warm or start arcing. Keep an eye and don't spray water anywhere where it could drip don into the plug wells, if they don't crack, they will certainly foul out before long (if they have water in them). The plug wires could shrink, but I wouldn't think this is the problem, because I don't think they would shrink enough to crack the plugs. Good luck!
Old Jul 4, 2003 | 02:11 PM
JMC's Avatar
JMC
25 Year Member
stx98,
Make sure your plug wires are properly installed. Pay special attention to the plug boot. If it is not properly seated on the plug it will not seal in the plug well. If it is turned the wrong way, they are cut on an angle, it will not seal in the plug well.
Regards
Jean Marc Chartier
Old Jul 6, 2003 | 04:38 AM
stx98's Avatar
JMC,
WHAT KIND OF PLUGS DO U USE? IS THERE ANY TYPE OF SEALER TO BETTER SEAL SPARK-PLUG WELL?THANX stx98
Old Jul 6, 2003 | 01:30 PM
JMC's Avatar
JMC
25 Year Member
I have Denso Iridium plugs. My truck has COP, Coil on Plug, ignition so the only system to use is OEM. The factory plug wires are a sure fit. Some aftermarket wire sets do not seat on the spark plug properly and they come off and this exposes the well to the elements. Get water in there and all kinds of nasty things can happen.
JMC
Old Jul 7, 2003 | 07:52 PM
stx98's Avatar
PLUGS
JMC,
ME AGAIN MY PROBLEM IS THAT I'M GETTING WATER IN PLUG WELLS. HOW OFTEN DO U HAVE TO CHANGE WIRES AND HOW COME WATER GETS IN THERE ANY WAY? THANX FOR PLUG INFO.
stx98.
Old Jul 8, 2003 | 08:49 AM
JMC's Avatar
JMC
25 Year Member
stx98,
No water should be getting into the plug wells. The spark plug boot serves 2 purposes. 1st it makes the electrical connection to the plug and 2nd it seals the spark plug well. The wires should only be changed when they become damaged or fail to properly conduct the electricity to the plugs. A cheap test is to spray water from a spray bottle onto the wires at night and check for sparks. If you see sparks then change the wires. Often times improper removal technique stretches the wires and the core brakes. This leads to arcing of the wires.
If your wires are properly installed and they make a perfect seal in the well you should not have any water intrusion in the plug wells. I have heard of rare instances of a casting flaw that allowed coolant to seep through the head and accumulate in the plug well. Do you have water or coolant in the plug wells? Do you power wash the engine?
JMC
Old Jul 9, 2003 | 09:02 PM
stx98's Avatar
JMC,
IT'S ME AGAIN. IT'S NOT COOLANT,AND CHECKED WIRES NO SPIDERS(THATS WHAT I CALL IT AT NIGHT WHEN WIRES LOOK LIKE WALKING) I WENT THROUGH ALL WIRES THEY APPEAR TO BE INSTALLED PROPERLY, GUESS I'M GOING TO CHANGE PLUGS AND WIRES THIS WEEK-END I KNOW UR IN CANADA BUT WHERE DO GET PLUGS AT,THAT IS ONES U TOLD ME ABOUT GET TIME HELP .
stx98
Old Jul 9, 2003 | 09:05 PM
stx98's Avatar
JMC,
FORGOT I USE TO PRESSURE WASH BEEN BLOWING DOWN WITH AIR AND HAVE NO PROBLEMS
stx98 thanx
Old Jul 10, 2003 | 08:16 AM
JMC's Avatar
JMC
25 Year Member
stx98,
I got mine from Mike Troyer.
Mike Troyer
Troyer Performance/Performance Products, Inc.
Truck & SUV Performance Specialists
Web Site: TroyerPerformance.com
(540) 862-9515
Email: Sales@TroyerPerformance.com
National F-150 Online Rally Event Organizer
