HELP coil pack specs
Old Jun 5, 2003 | 02:33 PM
Randy Taylor's Avatar
I have a 97 4.6 with 95k mi.It has a miss around 3k rpm,replaced fuel filter no help.I just pulled coil packs to check and found this Primary specs are 0.3 to 1.0 ohms,I got .9 ohm,OK I guess.
Secondary specs are 6.5k to 11.5k ohm, I got 13.4 to 13.8 on all adjacent cyl.A little high,This was done with packs removed and on bench.
Does anyone know if this would cause the problem? I am running motorcraft dbl plat. about 1 yr old and MSD 8.5 super-conductor wires also 1 yr old Idle is very smooth at 500rpm in drive.
Thank You for any help,
Randy
Old Jun 5, 2003 | 03:36 PM
fieldthis's Avatar
Assuming you have two coil packs, one on the front of each head, I think you have the wrong specs. Out of a chiltons online manual it says "Resistance should be 12.8-13.1 kilohms. If secondary resistance is not within specification, replace the coil pack."
Don't know if that helps. Still sounds like you are out of spec, but not as much.
Good luck
Rob
Old Jun 5, 2003 | 03:58 PM
I got these specs from my Chilton manual,now I need to know which one is correct.
HELP SMEONE,I have to order them by tommorow to get them Sat.
Old Jun 6, 2003 | 03:12 PM
PLEASE HELP,which manual is right
Old Jun 6, 2003 | 03:53 PM
fieldthis's Avatar
I found the spec's that you found, but there in a section that refers to a 4.6 with a Tfi-iv distributor system. If yours is like mine it doesn't have a distributor. Look in your book for a section on distributorless ignition system, thats where I found the specs that I gave to you.
Rob
