valve spring on 4.6
Old May 21, 2003 | 12:20 AM
oddorjo's Avatar
Unhappy valve spring on 4.6
valve spring on # 3 exhust is broken Has anyone had this problem if so was it easy to change i have the valve cover off and all of the vac lines and wires move out of the way or if there is any one in albuquerque that can help thanks
Old Jun 8, 2003 | 10:30 AM
sc150's Avatar
www.crownvic.net has alot of info on replacing valve stem seals.
I used this info and replaced the seals on my 1994 GM 180,000
miles this past week. My engine is 4.6 in the
Grand Marquis. Did the valve seals with the enigne in the car,
without removeing the heads or the cams.
I used the valve spring compression tool
from www.thetoolwarehouse.com.
