mass airflow sensor-part#
Old May 17, 2003 | 06:53 PM
*hammer's Avatar
Truck is stalling out 2-3 time's a week and is becoming a problem since I never no when or where it will happen.I changed my air filter to a k&n and installed a new gasoline filter.After doing some research I think it is my mass airflow sensor(MAF),I hope anyway.If anyone knows the part # I would appreciate it,or has had the same problems maybe you can help me out.THANKS
Old May 18, 2003 | 07:54 AM
pjf77's Avatar
If you think it's the MAF try cleaning it with some electronic contact cleaner. It could just be dirty, and it would be a much cheaper fix.
Also, i see in your sig that you have a superchip. Did you check that to make sure it hasn't become loose. Just a thought.
Old May 18, 2003 | 07:53 PM
KYFordFreak's Avatar
I agree with pjf77 sounds like a loose super chip problem. I alos see you have a system which means you are putting a strain on the charging system. You might have a ALT. that is going shot or a loose batt. connection.
