Tek Question
Old Apr 17, 2003 | 02:28 AM
Habibi's Avatar
Tek Question
Hi,
If I want to have my cats flow tested the next time im in for service, how long does this test take, and what would I expect to pay. (I don't know how long it takes)
Thanks in advance
Habibi
Old Apr 17, 2003 | 09:15 PM
Tailgator's Avatar
Don't know about having them flow tested,but you can have a backpressure test done on them with a back pressure gauge screwed into the upstream O2 sensor ports. This will tell you if the cat's are restricted. Backpressure should be around 1-2 PSI......anything higher than that the cat's/exhaust are restricted. Shouldn't cost anymore that an hours labor to do this. Hope this helps!
Old Apr 17, 2003 | 09:32 PM
Habibi's Avatar
Thanks for that Tailgater,
That was a big help.
Regards
Habibi
