4.6L Stroker
Old Apr 3, 2003 | 07:56 PM
Magnum88C's Avatar
4.6L Stroker
Since the 5.4 and the 4.6 both have the same diameter pistons, is the 5.4 just a stroked 4.6? I figured with all the hoopla over the "mod motors" the 5.4 is just a stroked 4.6 with different heads, etc. With that in mind, does anyone make a stroker kit for the 4.6? Or owuld one be able to change the crank, rods, heads, etc by just putting in the 5.4 parts? Would the computer and wiring harness need to be replaced? Would you need a custom burn on a chip, or would a programmer that works on 5.4s work also?
Ok, enough questions.
Magnum
Old Apr 4, 2003 | 10:35 AM
JMC's Avatar
JMC
25 Year Member
In a nut shell. The 4.6 and 5.4 use different blocks. The 5.4 being the taller one. Basically anything that has to do with increased deck hight can not be shared. They use different intake manifolds, front covers and crankshafts. There are kits available to stroke the 4.6 to about 4.9L or 300 cu in.
Regards
Jean Marc Chartier
Old Apr 4, 2003 | 10:11 PM
Magnum88C's Avatar
Thanks JMC.
By the way, what happened to the cool mud-spray pic you used to have under your name?
Magnum
Old Apr 5, 2003 | 12:52 AM
JMC's Avatar
JMC
25 Year Member
Magnum,
Thanks for reminding me. I edited my profile for my new e-mail addy but I forgot about the picture.
JMC
Old Jul 31, 2003 | 03:46 PM
tog's Avatar
tog
after deciding on keeping my 99 4.6 4x4 until it dies,, i am looking into power upgrades,, jcm? who makes this kit you speak of?
Old Jul 31, 2003 | 04:11 PM
JMC's Avatar
JMC
25 Year Member
Tog,
try Modmax;
http://www.modmaxracing.com/
Fox lake;
http://www.fox-lake.com/index.php?su...Max%20Strokers
SHM;
http://www.seanhylandmotorsport.com/...og_pg1_3.shtml
If you are going to spent the $$$ that these places are asking for you might as well get a 5.4 and start from there.
regards
JMC
Old Jul 31, 2003 | 04:50 PM
tog's Avatar
tog
thanks jcm oh fordlord
will check em out
what you know about headers?
how much?$$$
how much it help?hp, tq
any reliabilty issues for high mileage down the road/?
who to install?
bryan or austin texas?
Old Aug 1, 2003 | 09:48 AM
JMC's Avatar
JMC
25 Year Member
tog,
I had hedman headers but I have switched to JBA. The JBAs were Neal the HP freak's old ones. He ported them and gasket matched them. He is using long tube headers now. Headers should get you about 10-12 Hp on the V8s.
I service my vehicle so I could not recommend anyone.
Regards
Jean Marc Chartier
