JET Low Temp. thermometer 180 degrees...
Has anyone bought this product. It's fairly inexpensive, but it seems like a good idea. The thermo. opens up at 18o degrees unlike the stock.
Do you think this is a worthwhile mod.?
mf150,
Get a chromed one. When you put it on your desk as a paper weight it will look nicer.
Unless you are into some serious mods that dramatically raise the CC temps then don't waste your $$$.
Regards
Jean Marc Chartier
Unless you are into some serious mods that dramatically raise the CC temps then don't waste your $$$.Regards
Jean Marc Chartier
HI!... It's been proven already that a N/A engine makes it's best power with it's temp between 190-200 degree's. We have a 193-195 stat in our F-150's. I beleive the LIGHTNINGS are running a 180 stat in stock trim.
Right on man. Did a search and came to the same wonderful conclusion!
