changing to larger radiator?
Old Mar 6, 2003 | 05:46 PM
Black Truck's Avatar
Question changing to larger radiator?
Is it possible (and worthwhile) to consider switching from the smaller radiator to the larger radiator? What would be involved?
Old Mar 6, 2003 | 07:49 PM
Bubbadewsky's Avatar
Cool
On my 2000 f-150 the original thin radiator was replaced by the thick one under warranty---everything bolted into place, the only new parts were the radiator. Is it worthwhile, depends on towing heavy loads uphill in the summertime and possibly sitting in a traffic jam in the desert for hours. If this is not what your truck will be doing then no need to change radiators.
Old Mar 7, 2003 | 11:48 AM
sooo_alive's Avatar
My 01 5.4 supercrew has the thin radiator. I was traveling through Boise last summer during record hi temps. While pulling my RV (~5500 lbs) in 107°F temps, I did not experience a problem.
One thing worth noting: when I asked the dealership about the radiator thickness (mine does have the factory tow package), the shop foreman told me that the '01s have an auxiliary radiator, not a thicker one - not sure if I believe him.
Old Mar 7, 2003 | 01:10 PM
MitchF150's Avatar
Lightbulb
If you are relying on the stock "gauge" to inform you on the engine temp, then don't expect much.
It's nothing more then a fancy idiot light. It'll sit at it's "normal" range from 150* to probably over 220*.
I've got Autometer Water and Trans temp gauges and so far I've not seen the water temp go over 195*, even when towing. Okay, it's still Winter, and I've not towed my #4500 TT with the gauge in the summer, but I still don't think there will be much of a change. Well, I guess I already have the bigger rad too, so I think my experience is moot for all you folks with the 1" rad anyway.......
Old Mar 7, 2003 | 07:32 PM
canyonslicker's Avatar
I think you have been mislead about the temp gauge. The oil pressure gage I agree. I know my stock temp gage reflects temperature changes unlike any idiot light .
Old Mar 8, 2003 | 12:41 AM
hapynzap's Avatar
I got a 2 row (2 inch) radiator from radiator.com for $190 bucks. Cheap insurance for my engine and aluminum heads I figure. I got a 98 4.6L. It's OEM replacement and bolts right on.
You may as well change your radiator hoses and thermostat while you are at it. I got my motorcraft replacements at fordpartsonline.com for about the same price as the goodyear hoses from the local parts house.
