Water Pump Help
Old Feb 18, 2003 | 03:53 PM
squid's Avatar
Question Water Pump Help
How hard is it to change out a water pump on a '97 4.6ltr.
Old Feb 18, 2003 | 05:01 PM
ROUSHFAN-1's Avatar
Very easy .....Drain coolant...Remove belt ...remove four bolts that hold on the pulley....remove 4 or 5 bolts (not sure) that hold pump on...pop off pump..pop new pump on ...install in reverse order...There is no gasket which you may be expecting...There is a rubber O ring on the pump which you may want to lube when installing new one..
Old Feb 19, 2003 | 09:54 AM
squid's Avatar
Thanks for the help. I'm off to Auto Zone!
