Intake manifold question
Guys -
I want to use the Derale electric fan thermostat with the 3/8" MPT fitting for the activation of my electric fans.
I was looking on the manifold of my 'Screw and notice a pipe plug, directly behind the alternator, with an Allen wrench head. It looks like it might be the right size, so...
I was wondering if anyone has a manual that says or has knowledge as to what thread that plug hole is.
I don't want to remove the plug to check because I don't have any way of identifying what size the plug is, without being at a Home Depot to compare the plug and get an exact match.
2001 'Screw, 5.4L, towing package...
TIA for any help...
TIA for any help...
For anyone wishing to use it, it is a 3/8" MPT fitting. Using this spot for the sending unit, my new Auto Meter temperature gauge reads right at 195* when the truck is running...
sending unit hole
b man,
i was wandering when you refer to the 3/8 hole behind the alternator was that hole empty because on my 97 f150 4.6 it has a sensor in it i was wanting to install an accurate temp guage and came across your thread stating that there was a hole behind the alternator that could be used for the sending unit on the new guage but as i stated the hole behind my alternator has a sensor installed maybe it for the factory temp guage. thanks in advance for any help. john
